94 radio wiring
Well i took out my factory radio and cut the clip i have done this in other cars before. But after hooking up my old cd player it seems it is not being grounded and the front speakers wont get power at all the backs do but are very quiet due to no ground but this all worked on factory radio is it the cd player it self or something i messed up pls help i have no music. :mad:
Anybody pls
Sorry, I am confused. Did you cut the factory electrical connector and directly wire to the new cd player?
I made the same mistake on my 97 accord. I cut the factory radio harness and tried to install my new radio (which didn't work). I later found out that there was a $15 harness connector I could've bought and just plugged my new radio right in. I would check your local auto parts store (or walmart) and see if they have a connector for your accord. They had one for mine which I could've used if I knew about it.
How about I move this over to A/V Elect.
Do not cut the harness from now on, not only does it make it harder on you it is also frustrating to whomever buys the car from you.
here is the wiring colors for your car. 1994 Honda Accord Stereo Wiring Information |
Those color codes are not matching up with my car
Well i got power to my cd player it is on i hooked up my speakers as it says. My right rear works but i must have volume up all the way to barely hear it. And they are the only ones working pls help guys.
My suggestion would be wiring your factory harness back in. then buying the adapter.
Thank you every body for the help i relized the prior owner rewired the harness thats why to colors were wrong also my cd player was broken bought a new one works perfect thank you evrybody
