96 Aftermarket Head Unit
Hey, I have a 96 vti-s.
I have an aftermarket HU and want to install that and keep the stock pocket underneath. Do I need a mounting kit for this? If I do is it a double-din one? Sorry, I know crap all about cars. Tried searching, didn't find anything specific. Cheers. |
You can use the factory radio brackets to install the aftermarket HU. It is called ISO mount. There may be a small gap around the HU, or the aftermarket trim ring may work.
Start without as I described and see, post pics. |
Thanks, I'll try it when I get the wiring harness.
But first... I changed the two stock front speakers with new ones and now the car will not start or do anything. It has no power or anything. I disconnected the neg terminal before starting and re connected it when I had the first speaker in, first one worked. Took the neg off again to install the second one, reconnected the battery once it was in...and NOTHING :eek:. No lights on the dash or ignition light thing. I'm freaking out.... Please tell me I didn't somehow blow my car up. |
Likely, the Ground is loose. Clean the terminal and tighten.
Originally Posted by keep_hope_alive
(Post 270264)
I just checked the elecs again and the only thing that works are the hazard lights. EDIT: So I tried it again; didn't do anything differently and it just decided to work. The light ring around the ignition doesn't light up, though. Everything else seems to be fine. |
2 Attachment(s)
The stock pocket wouldn't fit, neither would the "universal" one.
So I put the Aerpro one in without its faceplate thing 'cos it wouldn't fit with it on. So I'm just gonna glue it on, on top of the other facia. I know I could just shave down the faceplate a bit, but I don't think it's worth the effort of taking all the crap out again. What a damn nightmare that was... What kind of glue would work for this. Attachment 18608 Attachment 18609 One more question; can you change the firmness of the driver seat? Feels like I have a boulder lodged in my lower back when I drive. Sorry for the huge images. |
there may be a paddle on the right side of the drivers seat that inflates/deflates the lower lumbar support.
it is possible you loosened a harness behind the radio during install. odd that the mounting kit doesn't fit. i don't have issues with Metra kits fitting. super glue works but discolors the surface, silicone is removable - both would be needed to be glued from the rear so you don't discolor the visible front. |
Thanks for your help, man!
