Amped Speaker Question
Hi, I havent posted here in a while and since i have installed 6000k hids and blacked out the emblems but thats beside the point. I have Alpine SPR-69-C's on the rear deck and have Alpine SPR-50C 5-1/4" Type-R 2-Way Component speakers on the way for the front. The thing is that im running the stock headunit and i am underwealmed by the performance with the new speakers. I was of amping all the speakers but not adding a sub but was wondering if i could keep the stock headunit. Is there any way around getting a new headunit or would i have to to amp all the speakers. Also any suggestions for an amp? thing
you dont have to replace the headunit. I am confused as to why you wouldnt amp all the speakers but no you dont have to.
this would be my suggestion on an amp. MB Quart FX4.100 (fx4100) 800W RMS, 4-Channel Formula Amplifier |
I would be amping all the speakers but how would I do that without replacing the factory headunit and running new speaker wire to all the speakers.
you need a LOC (line outoput converter)
It takes the speaker level output from your headunit and converts it to low levels RCA's that you can plug into your amp. one like this NEW RCA Car Line Converter Output Adapter HI LOW LEVEL | eBay |
Yes, amping the speakers is required if you want them to sound good. I prefer an amp with high level inputs and auto turn-on running from the stock head unit, compared to just running a new HU. But the amp install is much more involved.
So the loc takes the signal from the existing speakers and converts it to rca which then goes into the amp?
Originally Posted by H0nda04
(Post 259829)
You intercept the factory speaker wiring and give the signal to the amp (all 4 channels), then wire from the amp to the speakers. There is a way to do this while using most of the factory wire, I can post a diagram later. |
ok any specific suggestions for a loc and amp for my speaker setup?
I suggested the mb quart amp. KHA may have another and he suggested the PAC specific for your car or a David Navone Engineering LOC.
Mb quart lacks an auto turn on, and is just a Maxxonics product. Kicker, Phoenix Gold, Sundown can offer an auto turn-on and high level inputs.
