Audio outputs
Does the EX Accord head unit come with audio outputs for amps, or do I have to use line output converters? I have the 6 disc, with XM, no navigation. Thanks guys.
RE: Audio outputs
Its on 05 by the way.
RE: Audio outputs
I have answered this question time and time again, so much that I can detect it when one start to even type the question. Your answer is no. It does not exist. You need to get a hi/lo converter. Or you can just swap a new radio in... which will do you better.
RE: Audio outputs
Only problem is, the 6 disc is in the dash and the front of the unit has a funky pentagon shape, I dont care what deck you put in there it's still gonna be funky. Anyway, yeah i figured as much, I'm just gonna go with the output converters.
RE: Audio outputs
I just put my subs in today, so i can assure u that there are NO outputs. I have an 05 too, and i used the converter. works like a charm!
AND you don't have to replace the "pentagon" shaped radio... That can stay in there, u just have to keep power to it if u have the EX dual climate control AC thing. They make a replacement pocket dash kit.... And it looks great..... here's the link http://scosche.com/scosche.aspx?Cate...ItemID=HA1573B |
RE: Audio outputs
Thanks for the link, I'm gonna stick with the stock unit for now. I was hoping for a miracle cuz I'll be running 2 mono amps and a 4 way, so that means I'll need to run one signal to my 4 way and split the other signal to the mono's. If it sounds like crap I'll upgrade the head unit.
RE: Audio outputs
before u do that.... at best buy we have a 4CH high/low converter..... speaker wire in, RCA's out..... hooray
RE: Audio outputs
ORIGINAL: danny6996 Thanks for the link, I'm gonna stick with the stock unit for now. I was hoping for a miracle cuz I'll be running 2 mono amps and a 4 way, so that means I'll need to run one signal to my 4 way and split the other signal to the mono's. If it sounds like crap I'll upgrade the head unit. |
RE: Audio outputs
speak for YOUR local best buy.... not all best buys are the same.... At the best buy i work at, we do POOP right!!! i know some best buys suck, but you can't say they all do
what's your beef with best buy? |
RE: Audio outputs
I apologise. I was referring to my local Best Buy. Come to think of it, once I was in there and I actually saw this dude drop a huge friggin Rockford amp! He just shrugs and continues on what he was doing!
