audio overhaul. but how to remove the existing equipment???
ok well yesterday i bought a 95 4dr EX. it came with an aftermarket HU but stock speakers. the speakers are pretty much shot, the surround has seperated from the cone.
anyways, i need to know how to get the headunit out so i can put mine in by removing the center dash, also how to access both the front and rear speakers, i tried to pry the cloth grills off but they were resistant so i wasnt sure if that was how they came off and did not want to break anything so here i turn to you all. also if i am correct, i understand my car has 6.5" midbass and tweets in the dash but cannot find the tweets, where are they located and how access them? i know this is alot of info i am asking for and it is most likely floating around here but havent found it. anyone who can help i would greatly appreciate. many thnx |
RE: audio overhaul. but how to remove the existing equipment???
Center console removal:
http://www.installdr.com/InstallDocs/Honda/Accord.html The side door speakers just grab the cloth grills around the speakers in the door and squeeze together a bit and pull and they should pop off.... the tweets in the dash can be seen if you look down the A pillar to where it meets the dash/windsheild tucked away in the corner and they just pop up and twist a little bit to remove them |
wow its a bit more intricate than ud think looking at the consol, np tho, thanks
Once you do it one time it becomes really easy. Good luck!
anyone know the mounting depth of the door speakers. id like to replace them with any xtra work
Try going to Crutchfield's website, they will be able to tell you what mounting depth you need for your front speakers.
