Basic CD Player/Radio Installation
Old Apr 3, 2011 | 11:22 PM
keep_hope_alive's Avatar
Originally Posted by Phobia
i got a quick question, i had my cousin install my Sony xplode radio a few days ago and it works BUT if i set a radio station, set the audio setting, or am in the middle of a CD it will forget. and i have to reset everything when I restart my car. got any clue on what it might be??
most likely your cousin didn't connect the yellow wire to a constant 12V source. he may have mixed up the yellow constant 12V and the red switched (ignition) 12V.
you should have bought a 17-1720 or 17-1721 (depending on the year vehicle) harness adapter so he just had to match colors. if he cut the factory harness; tisk, tisk.
Old Apr 3, 2011 | 11:34 PM
Phobia's Avatar
i had a wire harness adapter but both him and me cut it 2 short lol I need a new one my accord is a 96 so witch of the 2 do i need?? 17-1720 or 17-1721??
Old Apr 4, 2011 | 12:14 PM
17-1720 is for 97 or older. If you already cut off the harness, you need to solder and heat shrink the harness back on.
Old Jul 21, 2011 | 11:49 AM
dougiefresh's Avatar
Exclamation 2003 Accord Wiring Harness Issues
I really need some help. Is there a wiring harness out there where you can have both the stock 03 accord coupe screen and your aftermarket deck powered? Only my deck is powered on, so I can not see the time or my ac controls at night on my stock screen because only one can be powered on. Thanks.
Old Jul 21, 2011 | 03:21 PM
Get the 71-1721 harness to connect the factory radio as well.
Old Mar 1, 2012 | 08:50 PM
DarkCreep's Avatar
Is there ISO mounting brackets for the radio on a 5th gen? My Accord has an aftermarket CD player thats loose, I dont like that. I know on my Civic it has the mounting brackets and they bolts to an aftermarket radio so it doesnt fly around and harder to steal.
Old Mar 2, 2012 | 07:15 AM
  #17
crispin's Avatar
In my 97 accord there was nothing at all. The single DIN that was in there was just sitting in the space.
I could not figure out what was missing and how I was going to mount my double DIN DVD / NAV unit securely.
What I ended up doing was using some thick plastic pieces and some JB Weld and made my own mounting system. It was a PITA but came out good.
Old Mar 3, 2012 | 11:36 AM
  #18
there should be ISO brackets.
Old Mar 26, 2012 | 12:48 PM
  #19
neophyte's Avatar
shouldnt need a wiring schematic. use the proper harness and it will plug into the factory harness.
Old May 18, 2013 | 02:47 AM
  #20
dadcanic's Avatar
Question radio blues
The radio/cd player on our 1998 Accord ex doesn't play cd's anymore. How easy is it to swap it out for another Honda radio/cd player? will ones from other years work? are there any Premium ones or upgrades I could plug right back in from Honda?
