Buzzing in '03 Accord
Old May 21, 2005 | 09:30 PM
Quacker
Default Buzzing in '03 Accord
The sound system in my sister's '03 LX Accord makes a buzzing noise now, and I was wondering what the problem could be? I think it's a blown speaker, but I'm not totally sure. Is there any way to diagnose which speaker is blown?
Old May 25, 2005 | 04:20 PM
DIRTYCUBAN
Default RE: Buzzing in '03 Accord
It could be bad grounding wire, if it is an aftermarket system chances are it could be the grounding wire....
Old May 25, 2005 | 06:33 PM
remington870_20ga's Avatar
It could also be something called road noise which is not only related to ground wire but also positive wire. This happens when wire is contacting a metal surface or being pinched to one. You could also have a bad driver (speaker). I wish I would know where the problem is but this is a VERY broad question. Mind you, if you find the problem go to a radio shack or something and buy a ground loop isolator and splice it on in.
Old Jun 3, 2005 | 03:00 PM
Gummi_67's Avatar
I'd definitley say a bad ground. If it's an aftermarket speaker see if it is touching the body at all.
23Subs23
Sep 27, 2011 06:25 PM
msm2010
Mar 26, 2010 01:37 PM
ippikiokami
Jan 15, 2010 05:51 PM
journeyman846
Dec 1, 2009 04:49 PM
user125
Oct 21, 2009 05:23 PM
