A/c doesn't start after installation navi head unit
Hi guys,ι have a honda accord 2005 here in greece,and i upgrade my old simple head unit stereo to navi head (2006) unit together with the wiring harness original part honda from e-bay.Everything works perfect but i have a problem....a/c doesn't start when touching command on at the touch screen!!(A/C operating normally with the old unit)
Am i doing it wrong that I bought 2006 navi head unit ,and not the 2003-2005 version??? I am very upset because the sun burns from now on greece...please any help :( Thank's. |
could certainly be an issue with you buying the wrong year head unit. the controls are quite specific.
did you disconnect the battery negative after the install to reset everything? |
No!Should be done to work the unit??:)
any time you do anything to the electrical unit you should disconnect the negative post. Two times installing head units I have come across the A/C not working afterwards. Both times I forgot to plug the A/C control harness back in.
Thanks for the advice!
