changing radio
Hi im new here and recentley bought an 02' honda accord sport, can anyone tell me how i get the standard radio out because it doesnt seem to want to budge, would be much appreciated.
RE: changing radio
I know on my 96 accord lx, I had to remove the center console and trim. The console had some screws and then the dash trim snapped out. Then there was access to the radio. Hope this helps man.
RE: changing radio
My friend took the frame round the dash out, undone loads of screws around the radio etc and still nothing, ive never owned anything so well built, is there anything else to try?
RE: changing radio
there is a 10mm underneath the stereo that has to come out for the stereo to come out.
RE: changing radio
If it is like my 2000
there are 2 screws under the bottom and then you have to pop out the clock and take that center cover off. |
RE: changing radio
Yeah, those 2 screws are way back in there. They're almost past the radio its self. If you can't find them, grab a flashlight and try to see them. As I remember, the radio is connected to a little metal bracket by those 2 screws.
RE: changing radio
Ok guys cheers will have a crack at the weekend, the standard radio is not bad but nothing like my aftermarket head unit!
RE: changing radio
ORIGINAL: Gspot Ok guys cheers will have a crack at the weekend, the standard radio is not bad but nothing like my aftermarket head unit! you are right about that. the factory radio does not compare to even some of the crappy aftermarket radios. |
