Cofusing problem with my rear-view camera
hi
I've installed an aftermarket rearview camera and I've been faced with a confusing problem sometimes it's ok but when i park in outdoor camera dose not work properly and LCD showes a black and white picture (picture flickering) when camera is ok I have checked it's signal and it's about 1.2V but when it doesn't work properly signal is changing from .3V to 1.2V I found the solution by chance: when car is in reverse-gear if someone put his hands or somthing near the rear camera problem will be fixed and LCD will show the correct picture!!! Does anyone know the problem? |
Appears to be related to the ambient light sensor? That might be why it is affected by indoor vs. outdoor and why blocking the light helps. Seems that would be a wiring issue, maybe internally.
Originally Posted by keep_hope_alive
(Post 384200)
It was about gain control problem and camera should be changed as it was water proof |
