Earthquake sub
so i just remembered that my brother had a 12" earthquake sub. i THINK it might be a magma sub. it has a separate plate that looks like the surface of the sub (my bro calls it a radiator i think its called a passive disc)
he said i can have it if i can use it so YAY free sub has anybody heard of this sub? good/bad? know what kind of box to mount? i have a pioneer gm-x862 max power of 760watt will that do? http://www.bass-enterprises.com/inde...amp;ProdID=153 http://www.carstereoworld.com/Images...quake/slap.jpgpassive disc? http://www.lightav.com/car/earth/magma15.jpgsurface of the sub also looks like this if im correct that its a magma sub another site said 1500 watt max 500 raw RMS watts Superwide Edge Flat Piston subwoofer 3" DVC 3 Ohms ea. 95 oz. Stacked Magnet Fs = 27Hz Qts = 0.4601 Vas = 1.8 cubic ft Sen = 85dB Four-layer, dual 3" polymide coil (2 x 3.2 ohms) 95 Oz magnet SWE super wide edge, single, non-delaminating foam surround |
RE: Earthquake sub
I have never heard of them but for some reason they give me the feeling of a sub that you would purchase from Checker/Schucks/Craigen or walmart... I'd just hook the thing up and see how it sounds.....
I just did some quick searches/reading on those subs and I think I'm way off.... it would appear that they are really nice, they claim an octave lower than most subs in a sealed box and 22mm of travel....let us know how it sounds. |
RE: Earthquake sub
please doesw anybody know anything about this sub? or at least some info to help me out
RE: Earthquake sub
It is a decent brand. never hear one in person though. but thru the years I never really heard bad talk about them. I kno that the higher models are said to begood and need a lot of power to push them.
RE: Earthquake sub
1 Attachment(s)
yeah its a high powered sub i think. does my amp power have to match the sub's rms?
i read another post and found the answer to that question.... kinda. i think it said i can run lower power to the sub than its rms but it wont sound as good and that if i try to make up for it with volume/gains i might still blow the sub. but i dont thinks thats possible with a 1500watt max sub and a 760watt max amp right? because the amp will never reach that high of a spike? i'm still a lil confused but i think im ok i just really want to know how to mount this sub and passive disc Attachment 23557 im not tryin for a masterpiece but thats just a few setups that might be possible? does anybody know which one will work? |
RE: Earthquake sub
