factory wires
How could i wire an amplifier into a factory head unit, while having it wired to use the factory wires to play front door, and rear speakers? I have a 2010 honda accord lx.
rockford 6.5 component set front door upgrade rockford 6.5 component set rear upgrade rockford r250-1d amp Help! thxs |
crutchfield.com will see you all the connectors to make what you are trying to do work.
if you buy the amp from them I believe they will give you all / most of the connectors for free. |
Buy both Metra wire harness adapters, into car and into radio. Gives you access to all wires with no cutting and industry standard colors
