Fog light wires thru the firewall
i need to install the switch for the aftermarket fog light i bought. I have to run the wires thru the engine bay into the car. Where is the best spot to get it thru? I have a 94 accord. I found a spot above the fuse box inside the car where there is a rubber boot kind of thing with a whole bunch of wires coming thru from the engine bay. should i put it thru there? And do i just pull the boot off and press it back in?
Thanks |
RE: Fog light wires thru the firewall
Yeah thats the best gasket to go through. The best way is to cut a X in it and fish it through with a metal hanger. You could pop the gasket off the edge and pass it through there, but then you lose the seal.
hey! thanks for the reply. I just took the whole gasket off and passed it thru. it seal up pretty good tho. Thanks!
