Front Door Speaker Removal...
Is it possible to replace the 6 1/2" woofers in the front of an 02 Accord without removing the whole door panel? Can i cut the speaker covers off and access all the bolts to remove the speaker?
yeah i guess you could cut the covers off, but then how would you put them back on?
just take off the door, its not very difficult i promise |
It would be a lot more time and effort to cut the door panel, then it will look like crap....
It is very simple to take the door panel off, I'm not familiar with your gen but generally there are clips along the sides and bottom that to be released. Get a metal spatula, put a piece of duct tape on the spatula so you won't scratch the paint. Start from the bottom and make your way up the sides releasing the clips. Once the clips are released just lift the panel up and off the door. And carefully disconnect the cable from the door handle. I would google a more detailed instructions before having a go at it. |
http://www.6thgenaccord.com/forums/showthread.php?t=24
theres a good diy for 6th gens i didnt do all that taking apart the wiring harness. i bought one of those adapters from best buy so i wouldnt have to cut anything. made life simple but theyre also like 12 bucks |
dude
dude just be professional and not lazy lol your car will look alot better if you just take that whole panel off it doesnt take long maybe 30 minutes and make sure not try break the clips and put everything back together what year and model do you have ive had 4 accord 93 95 97 and now i have an 05 so i have replaced speakers in pretty much all accords PM with more questions
Thanks guys ! I'm all done, and taking the door panel off wasn't that bad after all. Just a piece of advice, be careful not to break the clips for the door handle. They are flimsy....pull the metal rod away from the plastic clip and you will be fine. :D
Yeah I broke a clip the first time I had to pull my door panels. I was doing it alone so I had to hold the panel with one hand, trying to unclip it with the other. If your experienced at it I'm sure you can do it alone but an extra pair of hands makes all the difference in the world. Glad to hear you were more successful than my first time.
