-   Audio/Visual Electronics (https://www.hondaaccordforum.com/forum/audio-visual-electronics-10/)
-   -   Front Speaker Buzzes (https://www.hondaaccordforum.com/forum/audio-visual-electronics-10/front-speaker-buzzes-39295/)
ltdanp21 Apr 5, 2011 09:57 AM
My left front speaker has started to rattle/buzz. It really is a cross between rattling and buzzing but closer to buzzing. It kind of sounds like a rattle-y "zzzzzzt".
When it happens: Say I'm listening to talk radio. Every time the host says something the speaker rattles/buzzes. When she's quiet, no buzzing. Every sentence = buzz. The louder she is the louder the buzz. Between sentences the speaker is fine.
Any ideas about what the problem might be?
Dan
JimBlake Apr 5, 2011 11:12 AM
I'm tempted to suggest the speaker cone is torn.
But I'll move this over to the A/V Electronics area where you'll get better answers.
ltdanp21 Apr 5, 2011 01:13 PM
one more detail. if i push firmly on the speaker cover, the buzzing stops.
if i can get to the speaker, will the tear be obvious to me?
JimBlake Apr 5, 2011 03:57 PM
Car type?
Is this the speaker in the door?
It's possible the speaker's mounting screw(s) are loose, causing the buzzing.
If the speaker cone is torn, you'll probably see it by looking closeley. Especially the outer perimeter where it flexes.
keep_hope_alive Apr 5, 2011 05:34 PM
tighten the screws that hold the speaker. better yet, when you remove the door panel to tighten the screws - put a layer of closed cell weatherstripping foam (1/4" thick) between the speaker and metal door.
when the door cover is off, play the speaker to verify movement and inspect the cone/surround.
ltdanp21 Apr 6, 2011 09:54 AM
If the speaker cone is torn, can I just use glue to repair a small tear or do I need to replace the whole thing? Perfect sound fidelity is not a major concern to me. Just don't want the buzzing.
keep_hope_alive Apr 7, 2011 12:41 AM
Depends.
trucknut88 Apr 7, 2011 07:02 PM
Mine was doing the same thing... All the foam holding the cone to the outside speaker casing was completely gone... LOL but it is a 1991... Replaced the speakers and it sounds great now.
