Ground wire
For you guys with the 03-07 accord, where did you ground the ground wire when installing an amp. In my old civic, i just had it bolted in with the tail light for 1.5 years and not one problem, but i want to place it somewhere thats hard to see. Any input would be helpful. Thanks
RE: Ground wire
Where did you mount your amp?
RE: Ground wire
I drilled 2 holes in the sheet metal in the pass thru, sanded off all the paint and stuck them there. But I mounted my amps close to the front of the trunk. You want to keep your ground wire as short as possible.
RE: Ground wire
Mine's bolted down with the trunk latch. The plastic comes up, and you can run the wire underneath, totally unseen.
RE: Ground wire
perfect timing. I'm going to have to address this soon.
can you go straight through the floor by the back seats, or is the gas tank too close? Also, will self tapping screws pass in the lanes, or do I need to do the bolt thing? |
RE: Ground wire
ORIGINAL: sir_nasty Where did you mount your amp? ORIGINAL: Briggz Mine's bolted down with the trunk latch. The plastic comes up, and you can run the wire underneath, totally unseen. |
RE: Ground wire
ORIGINAL: Thumper26 perfect timing. I'm going to have to address this soon. can you go straight through the floor by the back seats, or is the gas tank too close? Also, will self tapping screws pass in the lanes, or do I need to do the bolt thing? Go to MECA's website and get the PDF file of their install rules. Itll give you a really good idea of what is expected. http://www.mecacaraudio.com/sqlrules.aspx |
RE: Ground wire
there is a spot that something else is grounded on that i used but i have a feeling its actually not a very strong grounding spot. its like on a hump right behind the rear seat.
