headlights
He guys. I have an 09 ex-l coupe and was wondering what my aftermarket lighting optionz were. Can i put hid' s ina projector lense? What do you all recommend that i go with if i want to replace all of my lights? I want white ones. Not the factory yellowish white
Great and I hope you get your wish's..by the way..what kind of ranting is this your doing..!
Im not sure that i understand your response. Has anyone put hid's in the factory lense housing?
hey redrum, im gonna have to stick with you on this one. i have an 05 accord and pretty much curious bout the same thing.
there are several companies who make replacements housings and other companies who make HID retrofits.
Note that headlight performance is not dictated by the bulb but by the reflector and optics. you want to avoid changing the light source location as that will reduce the reflector performance. i bought some aftermarket projectors, and went back to stock because the coverage was much better with stock. This was a few years ago. possible that newer models (costing more) could balance coverage and distance. TYC seemed to make the better replacement housings. |
Thank you so much for your input. By the way do you know what size the fog light bulbs are? Im gonna replace them with led bulbs
Might send a PM to Auto Design (sponsor here) and see what they can hook you up with?
not sure on your fog lights, pull the bulb and see what you can get for an LED replacement. but note that some newer cars see LED's as an open circuit and trigger the bulb indicator.
