help 2004 ex accord code prob
ive got a x m stero factory with 6 disk changer built in i need to estract the code can anyone tell me how to to this
RE: help 2004 ex accord code prob
There are two methods of serial number retrieval for "electronic retrieval" radios. Which you use depends on whether or not you have the Navigation system.
Method 1: for all electronic retrieval models except ’03–07 Accords with the navigation system [ol][*]Turn the ignition switch to ON (II).[*]Turn on the audio unit, and make sure you see COdE in the display. If you don’t see this message, pull the backup fuse for 1 minute, and then go back to step 1.[*]Turn off the audio unit.[*]Press and hold the 1 and 6 preset buttons, then turn on the audio unit. The display toggles between two screens. The first screen displays a U and the first four digits of the serial number (for example, U2200). The second screen displays an L and the last four digits of the serial number (for example, L0055). Ignore the U and L, and write down all eight digits. Then go to step 5.[*]Go to your dealer with your car, its ownership and the radio's serial number. They will give you the anti-theft code. [/ol] Method 2: for ’03–07 Accords with the navigation system [ol][*]Turn the ignition switch to ACC (I).[*]Turn on the audio unit, and make sure you see COdE in the upper display. If you don’t see this message, pull the backup fuse for 1 minute, and then go back to step 1.[*]Turn off the audio unit.[*]Press and hold the top halves of the SEEK/SKIP and CH/DISC bars, and then press and release the PWR/VOL knob. This display toggles between two screens. The first screen displays a U and the first four digits of the serial number (for example, U2200). The second screen displays an L and the last four digits of the serial number (for example, L0055). Ignore the U and L, and write down all eight digits. Then go to step 5.[*]Go to your dealer with your car, its ownership and the radio's serial number. They will give you the anti-theft code.[/ol] |
nice post!
To be honest... I ripped it from tegger.com
Thanks anyway :) |
i figured it came from somewhere, especially with the nice bullets.
