-   Audio/Visual Electronics (https://www.hondaaccordforum.com/forum/audio-visual-electronics-10/)
-   -   HELP: How to remove factory radio? (https://www.hondaaccordforum.com/forum/audio-visual-electronics-10/help-how-remove-factory-radio-4793/)
mnaccord06 Sep 3, 2006 06:37 PM
Hey, I have a 2006 Accord Non-Nav, Auto Transmission. I was wondering if anyone had a pdf or a link showing how I can remove the factory radio?
Fenix Sep 4, 2006 12:41 PM
RE: HELP: How to remove factory radio?
haynes repair manual man, haynes repair manual
mnaccord06 Sep 4, 2006 12:47 PM
thankz for the help
vicn77 Sep 14, 2006 03:20 PM
1. take the trim off around your shifter.
2. pop out the coin holder (not an ashtray holder), there should be 2 screws there.
3. remove the cig lighter cluster. if you look underneath your radio/hvac cluster there should be 2 or 4 8mm bolts, remove those.
4. pop out the top dash with your vents in them. be careful they clips in them are tight and you may scratch or indent you dash. if you have one try and use a plastic panel remover.
5. should have 2 8mm bolts you need to remove.
6. slowly remove the whole radio/hvac cluster, be careful there are clips near the bottom of the unit that helps keep it in place.
not sure what you're doing so if you don't need to unplug the radio, don't unless you have the radio code.
have fun
