-   Audio/Visual Electronics (https://www.hondaaccordforum.com/forum/audio-visual-electronics-10/)
-   -   hookin amp up in 2000 accord ex (https://www.hondaaccordforum.com/forum/audio-visual-electronics-10/hookin-amp-up-2000-accord-ex-7387/)
Derek 02-03-2007 01:46 PM
I have a few questions about it. I searched a read someones post about getting the power wire through that lil gasket on the drivers side. Once i get it fed through there, how do I get to it? Just take apart the lower dash near the steering column? And do most people with accords just run the wires through the trim? And when getting the wires to the trunk, should I just go ahead and run wires through that lil door? Or is there somewhere else that would probably be better? Also, whats a good place for the ground? just pretty much anywhere in the trunk?
t00fatt 02-03-2007 02:13 PM
RE: hookin amp up in 2000 accord ex
To get the wire once its through the gasket, you should be able to stick you head in under the dash and grab it. I have found the best way to do it is to, put the battery terminal on before passing it. Once the terminal is on it makes it a lot easier to push it through the gasket, but you need to push it from inside the car into the engine compartment. Unless your going to use a terminal to connect to the amp then you can pass it from the engine to the inside.
If your going to pass it from the inside of the car to the outside, once you have the cable at the battery you need to cut it a few inches from the terminal so you can put the inline fuse on the cable. If your going from the outside to the inside first you can wait untll your done and use the excess cable from the end for the battery terminal and inline fuse. I hope that made sense I'm half asleep.
Then yes you just pass the power, RCAs, and the remote on wire through the trim pieces until you get to the seat. Then the best way would be to unbolt the seat and take it out, and follow the wire loom into the trunk. Or you could just it squeeze the under the cushions and into the trunk. Once your doing it you will be able to figure it out.
