how to input a radio code for an accord 94
I, I just want to know if some one knows how to input the code for the radio, in a honda accord 1994, I already have the code, but I dont know how to input.
thank you very much. |
RE: how to input a radio code for an accord 94
Ok, since you have the code there are several things you can do...first and formost would be to start the car, turn the radio on and input the 5 digit code into the radio using the factory radio preset buttons (ie 12345) then it should work. If for some reason you have entered a code in wrong (you will only know this after you enter the code in and nothing happens) then you will have to disconect the positive AND negitive battery terminals from the battery and touch them toghether for about 30 seconds. This will essentially drain all electricity from the car (and the radio). Then hook up the battery terminals and enter your 5 digit code into the radio following the steps above. Hope it works out for you...I know how much it can suck not having any tunes.
