i keep getting different answers
i have 3 subs that are 4ohm dual voice coil and i want to achieve a 2 ohm load. i keep hearing it is possible to keep a 4 ohm load or wire it to a 1 ohm load. anyone know if i can achieve a 2 ohm load or 1 ohm load?
RE: i keep getting different answers
only possible load u can get is a 2.67ohm load
http://www.rockfordfosgate.com/rftec...p;woofer_imp=4 |
Liam: There are a few options. I'm assuming that you intend to have the same power to all coils.
1) Coils per speaker wired in series, 8 Ohms per speaker. Speakers wired in parallel. ---- 2.667 Ohms total, as stated above. 2) Coils per speaker wired in parallel, 2 Ohms per speaker. Speakers wired in series. ------- 6 Ohms total. 3) All coils and speakers in parallel. ------ 0.667 Ohms, most amps are not stable below 1 or 2 Ohms. 4) All coils in series. ----- 24 Ohms Other arrangements will change the impedance, but the coils will not be balanced. For 1 Ohm, you can use 2 speakers and parallel 4 coils. If I were you, I'd go with Option #1, as recommended above. |
