KHA 2014 Accord HU Swap to Premium
9 Attachment(s)
I will use this thread to detail the process of swapping the stock non-touchscreen head unit from a 2014 Sport with the touch-screen model out of the EX-L.
I will include wiring diagrams for both, photos of both, and instructions on what fits and what has to be changed. I picked this up as a salvage unit for $210. https://www.hondaaccordforum.com/for...ine=1464328948 https://www.hondaaccordforum.com/for...ine=1464328948 https://www.hondaaccordforum.com/for...ine=1464328948 The first step to wiring up the new HU is figuring out what the harnesses do. Actual part number is 39101-T3W-A830-M1 from a 2015 Honda Accord Hybrid Lucky for me, the main 24 pin harness is identical. https://www.hondaaccordforum.com/for...ine=1464328948 The rest of the harnesses vary with being useful with the following differences: Harness B isn't needed - it has audio I won't use (has sub out) Harness C has HandsFreeLink and external AUX audio. Harness D has HandsFreeLink Harness E goes to the external FM Tuner - so I lose FM unless I adapt and feed my Alpine DVA-9861. Harness F only has ground and power but the Navi model adds a few other cables. Harness G has the lanewatch camera, and I need to check the harness against the base model because the harness includes the rear view camera. Harness H is i-Mid and the same Harness J is HandsFreeLink Harness K is the USB port https://www.hondaaccordforum.com/for...ine=1464328948 https://www.hondaaccordforum.com/for...ine=1464328948 https://www.hondaaccordforum.com/for...ine=1464328948 I referenced several schematics to figure out the connections. A 2013 Accord with Premium and Navi schematic https://www.hondaaccordforum.com/for...ine=1464328948 http://i38.photobucket.com/albums/e1...USchematic.jpg A 2015 Accord with Premium w/out Navi schematic https://www.hondaaccordforum.com/for...ine=1464328948 http://i38.photobucket.com/albums/e1...m%20203732.jpg |
2 Attachment(s)
This is the schematic for the 2014 Accord Sport non-touchscreen that I will be replacing
https://www.hondaaccordforum.com/for...ine=1464330773 http://i38.photobucket.com/albums/e1...0Schematic.jpg After comparing the schematics, it seems the only wire that I have to manually re-configure is the HFL steering wheel controls - assuming they will even work with the new HU directly since that wire routes to the HFL Controller on the premium model. |
2 Attachment(s)
https://www.hondaaccordforum.com/for...ine=1464629780
https://www.hondaaccordforum.com/for...ine=1464629780 I had to combine A harness and F harness power and ground to get the unit turn on. And it does require a code. I have contacted the seller requesting the vehicle VIN so I can look it up with Honda. https://radio-navicode.honda.com/ |
