Left CD in Factory Radio
Ok, so I'm an idiot. I'm pretty sure I left a cd in the factory radio when I took it out and replaced it when an aftermarket one. I know that to get the factory radio to actually play cds again I'd have to reset the code (which would be easy enough if I had it), but if I hook it up, as long as it has power, should I be able to get it to eject the cd without entering the code? I really don't wanna have to pay Honda to figure out the code just to get the cd to eject. Thanks!
RE: Left CD in Factory Radio
Well. i dont know much about the code and stuff, i know last time i left a cd in a cd player when i took it out of my car i just held the 2 power wires and the ground on the battery and hit eject, that might save ya the trouble tearing your dash apart.
take it to best buy and if the installer is in a good mood and he's not too too busy he'll see what he can do about gettin it out for you. just ask really nicely and you can get anything at best buy
If you plug it back up you will be able to remove the cd.
I hooked it back up and was able to retrieve the cd via the eject button. Hopefully I'll never need to use the factory cd player again though, because it does indeed require a code.
