looking for a good deck and speakers
i was thinking about gettin the Pioneer DEH-P6900UB because i heard it has good sound quality and you can hook up a harddrive to it. the price is a little high for me at the moment unless i install it myself. i was wondering if there are any other decks with a ubs port around 200 or less that you would recommend.
RE: looking for a good deck
have you looked at crutchfield? not always the cheapest place to buy, but they usually have almost everything on their site...
I dont know if i should get speakers first or a deck first now. My friend told me that if I get a deck first and turn it up too high i can blow out my stock speakers and have the replace them before I have the money for it.
If you get a super powerfull deck AND you crank it up too loud then yes you can blow your speakers but you'd have to be a bit wreckless and careless to do that... If you use common sense you'll have no issues.
agreed.
also, i would replace the speakers first...what year do you have? in my 07, the speakers are easy...the deck, not so much |
I have a 97. btw does anyone know the speaker sizes in the front and back?
IIRC correctly, in front they are 6 1/2, back are 6 1/2 in a big plate, which you can rig a 6x9 into. check crutchfield to be sure
yeah the back is 6.5in too. although they do have 4 6x9 that will fit. i most likely will be gettin 4 6.5in speakers though. should i get 4 of the same or 2 in the back that are different from the 2 in the front? are there any speaker recommendations? budget is $200 for speakers.
i would put the 6x9s in the back. you have to angle them a bit to get them to fit, and drill new holes in the rear deck to mount them...only thing is, they dont seal totally...not sure if that's an issue for you.
I just checked and the car has 6x9 pioneer speakers in the rear. Does that mean most 6x9 will fit? If so which would you recommend for around 100?
