-   Audio/Visual Electronics (https://www.hondaaccordforum.com/forum/audio-visual-electronics-10/)
-   -   Major amp problem!!! (https://www.hondaaccordforum.com/forum/audio-visual-electronics-10/major-amp-problem-49864/)
ihonda Aug 28, 2012 05:12 PM
I have a 01 honda accord 4 door. I ordered that terminator set from amazon about 3 weeks ago and i hooked it up, They beated for awhile and so when i decided to flip the box and set subs facing me i unplugged everything in my amp. Now when i plugged it in all it does is blink and no sound produces..
i checked the fuses and the power wire... any other ideas?! Please help I miss having my bass!
keep_hope_alive Aug 28, 2012 07:30 PM
i bet you either shorted the speaker wires. remember that you shouldn't see any bare copper wire anywhere, wire should be stripped the minimal amount to seat in the connectors/terminals. take a pic of how you wired the amp and we can evaluate.
provide model numbers of amp and subs as well. there are several MTX Terminator packages, which one did you get?
bellend Aug 30, 2012 07:28 PM
Test the speakers by measuring the impedance and making sure they aren't blown.
The disconnect the RCA cable to the amp, and make sure it turns on. If not check the obvious, grounds, fuses, power etc...
Step by step check every component.
