My radio is staticy, says cd
Hello
I had sprayed Clorox into the blower and vents to clear a cow dung smell that presented itself to me when I would turn on the blower. In the process I may have shorted the stereo because even at the lowest volume I get very loud static and "Cd" displaying on the AM/FM cassette player of my family's 92 Accord LX. Can I reset the stereo by undoing the electrical connection or did I short it out with the Clorox mix? Thanks Ken |
RE: My radio is staticy, says cd
Hello
I decided to exercise insanity (trying same thing and expecting different result) and the darned radio behaved itself and acted normally. Now how can I have a short unless the A/C ducts have apertures allowing the Clorox mixture to cause a short? Of course I sprayed the Clorox some time back; I fail to understand what was going on. I was going to yank #24 fuse from the under-hood panel to reset the radio. Oh well. PS; I have 1994 Honda Accord shop manual if needed. I know mine is a '92 but I got a lot of good from that and the '91 book. Thanks KT |
my guess would be that your chlorox mixture was shorting it out slightly but not entirely and then it dried/evaporated and cut off that path... If it continues to work fine I would assume that this is the case... if it starts acting up again I would bet that you fried something by killing a connection of some sort...
Where exactly did you spray the mixture into? The dash air vents? or the clean air vents from outside? |
