New amp for sub
Ok so if you guys recall i have a kicker zx350.4 which is running my fronts, and bridged to run a sub. The sub i have now is a 12" infinity kappa in a ported box. I was thinking about getting another amp, as i know tOOfatt recommended i do. My sub is a dual 2 ohm so can be set to 1 or 4ohm, so i dont want a mono, as most give their full potential at 2ohm, and significanlty less at 4ohm. I was thinking either the kicker zx250.2, which is good for a 4ohm load bridged and gives you 250rms, or the kicker zx350.2, which is the same, just 350rms. my sub is rated at 350 rms but could i get away with with the 250 since i have a ported box?? what do you guys recommend?? And i know ive asked this a million times but these 2 amps will be fine on stock electricals?? just wanna make sure. I will be using my zx350.4 to run all my inside speakers if i get this.
The JL Slash 250/1v2 amp is 1ohm stable, and one hell of an amp. It isn't cheap, but no 1 ohm stable amp is going to be cheap. I can't think of any others that are 1 ohm stable, and this small. Going with the kicker amp is not a bad option either. The main benefit of running the JL amp is efficiency. The JL amp is digital, which is much more efficient than A/B swtiching amps. Digital amps also stay much cooler and I belive are less susepctble to clipping and power loss when it does get hot. If you can afford the JL amp, go for it, if not the kicker isn't a bad choice either.
With either amp you will still be far away from overloading your electrical system. |
ok thanks, the only problem is that the guy i get my stuff from cant get jl products :( or else id give it a try. As for the kicker amps (which i have come to love after switching my alpine for the zx350.4), will my sub pound with the zx250.2 or will the 350.2 make a big difference??
Well if your really want my opinion I wouldn't waste the money getting a small amp just for that sub. It really isn't a great sub. But if you want to go that route, I would go for the 250.2 just because it is cheaper. A small quality sub would be much better. One option would be to get a 500w amp and run the kappa off it until it blows, than replace it with a nice type-r, or a even a 10" CVX is nice. I just heard my first 10" CVX and was surprised by the SPL output, and as with any 10" it had very nice SQ.
ok so i got a 300rms 2 channel mtx amp for my sub, so now i will have that amp as well as my zx350.4. I am still within the limits of my stock electricals correct?? I have done no modifications at all to the electrical system such as big 3, etc. Am I still safe??
Very safe, the big three doesn't do anything but help stabilize the voltage when your drawing a lot of power. Even with your smaller battery your just fine, just don't blast music for too long with the car off. MTX makes some nice amps, good choice.
hey just asking a question for a friend. He has a rockford p400-4, which says it is 4,3, or 2 channel. But there is a switch on it that lets you select either 2 or 4 channels. how do run this amp with 3 channels??
you set it to 4 then bridge one side like you had your amp. I'm on my iPod sorry for the short response
the kicker 350.4 is mainly used to run all for door and deck speakers in the rear... a sub amp is mainly used on a mono block class d setup to get the best wound out of your system . i run a kicker cvr 15 2 ohm and a kicker 300.1 amp witht he remote bass controller it sounds VERY good but running a multi channel amp would def give u more Siganl to noise ratio being that thoses multi channel amps are mainly built to amplify Vocals and not bass id really go ahead and buy u a good hifonics amp mono block and call it good :)
Originally Posted by streetlimitz89
(Post 168783)
