New Metra 7803G problem
Hello. I just installed this new radio/HVAC system in my 2004 Accord yesterday along with a Kenwood KDC-X395 CD Receiver
and I thought everything worked fine, until I started it this morning and realized that the HVAC buttons do not light up. I had to turn the inside lights on to turn on the heater. A search online found a post saying that in another Honda forum, it was determined that the Metra wiring instructions were wrong, but I have not been able to find an answer. I contacted both Crutchfield( where I bought it) and Metra, but have not been able to find a solution. Does anyone have any ideas? Thanks |
Crutchfield and Metra should both be able to tell you which wires to ensure have power in order to have working lights. you will need to use a DMM to measure voltage at the harness to verify if it is an internal issue with the kit or a wiring/fuse issue with the car/install. have you verified the fuse serving the dash lighting is good?
