Question: Installing front speakers on Accord 2005
Hi,
I just started installing my system on my accord 2005 (my car version is the European one) and found out that the covers of the tweeters weren't grills but a simple plastic cover with a grille texture... :( so i made a cup hole in the grille and installed my component tweeters. Now i went on installing the speakers (Mid) to my surprise i wasn't able to pass my speakers cables to the amp located in the trunk. so for now I used the OEM harness, until i find a better solution. I am not satisfied with this solution because i am using premium cables for a high end component speaker set, and the OEM cables are (hmmm...) very small and simple with a lot of connections on the way :( So my question is - how do i thread (pass) the speakers cables into the door without drilling the tin ? Thanks . |
You cant. You have to drill a hole. But its not that bad. You drill a small enough hole to fit the speaker wires with a grommet and it doesnt look bad at all. In fact you cant see it unless you purposely look down to find it.
I thought those tweeter covers were a grill too. What I did at first was cut a hole out of them and then wrap them in grill cloth. Later I got better results mounting the tweeter on top of that mounting plate. I just mounted in that hole I cut out months earlier. You will get better performance out of them with them mounted on top like that. With them mounted inside the dash, youre hearing what is bouncing off the windshield. With them mounted on top of the dash, youre getting to hear them. |
Originally Posted by MacLeod
(Post 190849)
I thought those tweeter covers were a grill too. What I did at first was cut a hole out of them and then wrap them in grill cloth. Later I got better results mounting the tweeter on top of that mounting plate. I just mounted in that hole I cut out months earlier. You will get better performance out of them with them mounted on top like that. With them mounted inside the dash, youre hearing what is bouncing off the windshield. With them mounted on top of the dash, youre getting to hear them. Thanks about the drilling I am not sure i want to Drill a hole i want to keep the car OEM as possible :( |
You can drill out some empty pin spaces in the molex plug. Kind of a pain. i did it in my car. Well worth it though. I only had to deal with the drivers door in mine. Passenger just has hollow boot. I was able to fit 16ga monster through and all the way to the back with no interuptions.
Originally Posted by My03Accord
(Post 191219)
The boot clips on around it. Then there are 2 plugs that come out of there. Covered in grease. Pretty messy. Unplug and see what kind of free space.
I am trying to replace my Honda accord DX 2005 front door OEM speakers.
I have opened the door part but then I have struggled a lot to take the speaker our from the door frame but could not take the speaker out. Any help would be appreciated id you can suggest how to remove the speaker from the front door panel. |
should be a couple screws and it lifts out.
Originally Posted by arnabdutta
(Post 328611)
do you have mounting adapters for the new speakers? they will not connect to the existing holes without an adapter. you can buy them or make them out of waterproof materials.
be sure to use weatherstripping foam around the new speaker to seal against the door panel. that seal is required for bass response. |
