Quick wiring question
1 Attachment(s)
So I am wiring up my harness. All the wires match up, and then I am left with two grounds, one on each wire. They look like such. What should I do, ground them out to separate points or could I connect the one coming from the metra harness ( the one with no connector on it) to either the system remote control or reverse gear wire, both of which are unused. Any help is greatly appreciated.
Attachment 18201 |
the ground from the harness you don't need. ground the head unit to the chassis using that spade terminal.
sorry for the delay. i assume you already did this. |
