radio reset
How do I reset the radio in a 1995 accord? I've put the security code in but nothing seems to happen. Is there a unique way to insert the code?
RE: radio reset
When you turn on the car does the word 'code' come up on its little screen? All you should have to do is enter the code. I have heard that if you keep trying to enter an invalid code the radio will shut down and you will have to do a whole reset on the car. But if you did everything else right and it still doesn't work get your code verified by the dealership.
RE: radio reset
Just undo the battery for a few minutes hook it back up and enter the code if it doesnt work try again.
RE: radio reset
You need to unplug your battery for about 30 sec. Then if you have the radie code put it in. It's a five digit code.
If you dont have it just go to the honda dealership you got it at or just go to the local dealership and they'll look it up of line. they may have to pull the radio out and get the vin # off the top of the radio. |
