removing oem stereo on 92 accord
im having the hardest time removing the stock tape/radio on my 92 accord ex. if anyone has any help or suggestions i could really use them right now. thanks
RE: removing oem stereo on 92 accord
I am not entirely positive on the steps for this year/make, but I can give it a try. It looks like you need to remove the trim around the radio (should just be able to pull it off) then once this is off you should be able to undo the screws/bold that are holding the radio inplace...I will try to see if I can give you a better answer in the next day or so
thanks. ill give that a shot.
what u need to do is actually look behind the radio. if u get a light and look u should see a metal braket coming off the back of the radio that is bolted down with two 8mm bolts. u need to unscrew those bolts to remove the radio. best way is to use a 1/4 drive ratchet 3-6 inch extension and a universal joint bit. put the socketon the end of the universal joint. there are two bolts just loosen one from the driver side and the other from the passanger side. then it will pull out.
