stereo interface
I have a '98 accord and would like to integrate a stereo jack so I can hook up my MP3 or android. Does anyone have the information for the connectors on the back of the stereo and which pins I can tap to solve this problem.
thanks |
Integral cd changer or single disc? The head units with a cd changer integral do not have AUX input capability. But the radio is easily replaced. Buy a new head unit that has a front AUX and USB.
The integration modules for other radios are $100 anyway. The HU is a better option all around. I recommend Alpine or Kenwood |
it's a single CD with an optional tape (at least that's what the front of the stereo says. I've been trying for months to find info so I can hook up my Ebay purchased steering wheel controls as well. There are available pins on the back of the radio and I'm hopeful that there's a solution there. This is my back-up car, so I'd rather not put too much into the stereo.
Thanks |
Integration could cost more than an aftermarket used deck.
Your deck may not have steering wheel control capability, did you verify that already? if it accepts a tape deck, it should be able to get an analog audio signal in. The trick is figuring out what pins to put a load on so the radio knows to look for the audio signal. |
I don't know how to check for the steering wheel control. I was thinking the same thing about the tape deck but I didn't know what pins were the correct ones.
sadly, this information is poorly documented for factory radios.
One last question. How do you know if it's 2 din or single din?
