Stereo won't work after installation of new battery
I changed my battery last night and this morning, when I tried my radio out for the first time since the battery switched, there was nothing on the screen except for the clock. That A/C and heater adjuster appeared okay. I can adjust and fix the clock without any problem but there's no sound, no words not even a prompt for the code for my stereo! Does anyone know what happened? Any advice would be very much appreciated, thank you.
have you tried disconecting and reconnecting the battery?
Yes, I just did that. I unplugged the (-) for about ten seconds, but it's still the same. Should I unplug it and leave if off for longer?
try an hour or so. that should allow enough time for the radio to reset. if that does not work i am not sure other than did you push the power button to turn the radio back on?
I didn't know there's a power button? Let me do that first, if nothing happen then I will leave the off for an hour. I'll let you know what happens, thanks.
power button on my is right in the center of the volume knob.
We don't know the year or trim level. More infor please, including what stero option you have.
you are correct sir. I assumed that it was a 7th gen cause he made it sound as if the ac display, clock, and stereo were all in the same screen. I probably should not have done that.
Your assumption is likely correct, but we'll verify anyway. :)
Its a 2008 honda accord and I feel so stupid but I figured out what the problem was. It wasn't even turn on!!! Btw, I am a girl. Thanks you guys for all the tips!!!!! :)
