sub and amp for 09 accord
I have 2 infinity 12" subs, along with a 1200 watt amp and cap, I'm wondering if I need to get a new deck for the car for the components to work. It seems like it would be a little tricky to have an aftermarket deck because the stock cd player and everything else are so close together. I'm sure someone knows the answer to this, or someone has done it. Thanks for the help!
1 Attachment(s)
no you do not need a new deck
You need a Line Out Converter - about $10 on ebay take you cap and throw it in the trash as they are complete garbage and do nothing at all. Here is my Honda Attachment 18731 |
you dont need one but your post is confusing. the deck is the cd player unless you have an external disc changer.
you will need this, it ties into the speaker wires and gives you the RCA output that will then go to your amp
RAPTOR LOCA25H ADJUSTABLE 2 CHANNEL LINE OUT CONVERTER | eBay |
N-RHL2 - BEST LOC IN THE WORLD!! - $24.95 : Zen Cart!, The Art of E-commerce
This is a better LOC and has a turn-on circuit. |
Originally Posted by keep_hope_alive
(Post 264952)
This is a better LOC and has a turn-on circuit. I already bought a Scosche LOC80 but I know the quality of Scosche can be quite poor: http://www.amazon.com/Scosche-2-Chan.../dp/B00009UHRE |
Originally Posted by Sparkknocker
(Post 265574)
I am installing two Rockford P3's and a Rockford 1000w mono sub into my factory 07 Honda Accord. I want to keep the oem stereo. Will this LOC work with this setup? Seems to have a lot of wires coming off it. Sorry, I'm a noob when it comes to radio stuff. Thanks
I already bought a Scosche LOC80 but I know the quality of Scosche can be quite poor: Amazon.com: Scosche Loc80 2-Channel Adjustable Lineout Converter: Car Electronics It is pretty easy to install |
if u go to ur local car audio shop they can give u a loc then and there it may cost more but if u dont wanna wait then its worth it. i got 2 kicker comp 12s in my 04.
Just make sure the LOC has an auto turn on if the amp doesn't.
No amp should be triggered by ignition alone. |
Originally Posted by drew&dixon1718
(Post 265581)
