subwoofers for 1993 accord
i have a 1993 accord LX and i want to put either one 12 or two 10's in my trunk im looking for somthing that will give me a clean low bass the only thing im worried about is my car ratling too much any ideas for wut subs would work good?
RE: subwoofers for 1993 accord
That depends mostly on your price range. If you want to reduce rattle, invest in dyno mat and do the entire trunk. So what price range are you looking at. Also this is not the correct section, a mod will move it to the A/V section so no need to make another one there.
The A/V section only let you post in a special way, so thats probably why its here...
As for rattles... my trunk doesnt rattle too bad, its other interior pieces like the dome light that make most of the noise for me. If you dont want to shell out $$$ for dampening mat, the cheap expanding foam insulation has been reported to work wonders, along with carpet padding. |
I moved you this far to this forum..keep it posted in the correct forum :
Thank You :) |
sry about putting this in the wrong forum im new here so i wasnt to sure where i shud put the post. Im thinking about spending $600-$700 im not really too sure wut an apropriate amount of money would be.If i need to i wud be willing to put in more $.
I absolutely love my 12" CVX and ZX750.1 combo. My sub is louder than most dual sub setups, but still has pretty darn good SQ. The CVX won a few SQ contests when it first came out, it may have won more I just know about those when I was researching the CVX. If you really want the best sub I would for a JL 12" W7 with a quality 1000w block. The W7 is just about the best sounding sub in the industry, but not the loudest and is only a bit over your price range.
my main focus is on SQ. Loudness would be a plus but id rather have good clean sound insted of distorted loud bass.I was looking into the MTX Thunders they seemed pretty good i listen to a lot of techno nd rap nd with the techno songs i dnt want the bass to be delayed wud a 12in sub be ok with a faster beat?
A 12" would be ok with fast bass, but a 10" would be better. A 10" will give you the best SQ, 10"s have a nice tight clean bass to them. Sounds to me like you would love a 10" W7. The W7 is the best SQ sub hands down in my opinion.
im definetly considering those but i may be re-thinking about how much i want to spend on just the sub if i spend too much on the sub i may not be leaving enough $ for amp. (and if needed a cap.) so if u have any ideas of somthing that would be a little bit cheaper but still have good quality tht wud be great
hushmat is the equilevnt of dynomat, but slightly cheaper
ORIGINAL: t00fatt That depends mostly on your price range. If you want to reduce rattle, invest in dyno mat and do the entire trunk. So what price range are you looking at. Also this is not the correct section, a mod will move it to the A/V section so no need to make another one there. |
