Tweeter Cover Removal
Hey Guy's, Anyone know how to remove the tweeter covers in the dash on a 2005 Accord EX-L? I' m apprehensive about digging away on them and breaking them. So I'm hoping someone here has done this before and can help.
Thanks |
RE: Tweeter Cover Removal
i just did this 2 weeks ago and customly put in polk momo tweeters.,... its simple... get a flat screwdriver and lift up the front of it ... do it gently so you dont but a crease in the dash there are 2 spring clips in the front that will pop out and then pull the grill towards you so that the back releases... there are no spring clips in the back but there are clamps that slide under the dash in the back... if you need pics let me know and i'll take some and send it to you. Good luck
Cool! Thanks alot man that really helps. I'm gonna give it a try and I may ask you to post those pics depending how it goes, but sounds easy enough.
i was about to do the same thine... do you know where the wires run to?? i need to hook them up to a crossover... dont really need to pull new wire for a tweeter.
they run down to the headunit.. but i would just run new wires that;'s what i did you can run a thicker and better gauge wire and it will sound clearer and better because it carries a stronger signal...
