whats ur opinion on these subwoofers?
well i no longer have two 15 inch mtx subwoofers. someone broke into my car and stole them. Well today i bought two 15 inch power acoustik BM-15W for 150. it was 50 for each sub and 50 for the sealed box?
Was 150 worth it? they knock alright.. [align=left] [/align] |
RE: whats ur opinion on these subwoofers?
yea i heard of them.. they're a great quality sub.. but not known to hit the hardest.. but i cant see how a 15' doesnt hit that hard and only sounds "alright" lol... but for $150 you gota pretty koo deal on it.. if your lookin for max power get that new alpine amp.. i forgot the exact name but best buy just released it 2 weeks ago.. Really good amp... or you can switch to Best Buy brand "INSIGNIA" i heard them and they sound real nice and beat all competitors Price.... should look into those...
ORIGINAL: Jay 3rd .. but i cant see how a 15' doesnt hit that hard and only sounds "alright" lol... |
I agree with t00fatt, sub size doesn't matter if your amp doesn't have the balls to back it up. My buddy had a single 10" Alpine Type-R and another buddy had two 12" Type-R's. The 10" hit WAY harder. Even my Type-E's can outperform the Type-R's in certain scenarios. Also important to consider is what kind of car they're in. In the 10" vs. 12" scenario above, the 10" was in a Honda CRV while the 12's were in a Toyota Camry (blah).
i am curious..
is their anyway to prevent my rear view mirror from shifting out of place?? besides turning down the music and bass level.. im on -4 on bass level and it still rear view mirror still goes straight up... |
At least your mirror goes up... mine goes down. I think it was once suggested to pop the mirror off the ball and coat it with rubber cement or silicone caulk and place it back on to hold it in place....
Yea I did just that with my last car, I popped it out and sprayed the ball with plasti-dip. Its a rubberizing spray I use for waterproofing and griping for tools. Plasti-Dip.com. I haven't really had the problem with my accord, it happened for a little while then I just moved it around and it stayed in place.
ORIGINAL: t00fatt ORIGINAL: Jay 3rd .. but i cant see how a 15' doesnt hit that hard and only sounds "alright" lol... |
Well I'm sorry to say but what you said almost agrees with what I said. Yes your 15" may match up with a kicker comp 12" on the higher tones because of driver superiority. But what isn't true about what you said is that a larger sub from the same manufacturer is louder. That is a myth if I've ever heard one. Say with the Kicker CVR series, the 15" is not louder then the 12" in the high ends. Don't believe me, do some research and compare the response curves of each sub. Bigger doesn't mean louder in all frequencies. Each sub size has it own range, thats why different sizes exist. If it was all about size they wouldn't make a sub smaller then 12". The bigger the louder is a myth my friend. There are a different types of loud if you will.
you are correct in the way that a 12 inch may play 70hz louder than say a 15. But to say that a 12 is going to be louder is ncorrect, yes louder in some frequencies but not as loud in other frequencies. The size of the woofer has nothing to do with the type of use you listen to.15's can play rock and country as good as 12 or 10's. The only reason one should choose one side over the other is due to space requirements. If you have enough room than i will always suggest 15's. As well anyting above 80hz is mid bass and that should be handled with a good set of components or mid bass speakers.I personally have my subs crossed at 65 hz with my 15;s and with the 12's i had, any higher frequencies are filled in with my mid bass/range.
