Where do you run Amp Power Wire through firewall?
I have an 04 Accord 4dr and I was wondering where everyone has been running the amp power wire through the firewall to get inside the vehicle? I have to run some 1/0 ga wire and cant seem to find a place to run it through. I had a 4ga wire running through a hole in the frame into the car, but the whole is only big enough for a 4ga wire :(
Any suggestions would be appreciated :) |
RE: Where do you run Amp Power Wire through firewall?
ok if u have a auto then this is a simple fix u can drill threw your clutch plate i am not to sure if u have a standard haven't had to deal with that one yet
with a wire that THICK you gotta drill a hole... do what he said, right thru the clutch plate.....
Where is the clutch plate on the 05 honda accord 4 door
the clutch plate is just to the left of the brake pedal. just look for a cut out in the foam against the fire wall and you should be able to drill as big as you need.
Isn't it nice of Honda to prewire the cars for every factory accessory they make so they don't need extra holes in the fire wall.
