keep_hope_alive |
10-09-2011 06:40 PM |
it is a common myth that running RCA's next to power wire will cause alt whine. it won't.
what causes alt whine is a ground loop. resistance between the HU and amp grounds cause this. this is a common problem with Pioneer head units due to an internal failure and open connection. also, head unit grounding is important, i ground head units to the floor to minimize resistance.
you say you checked your ground, but show us a pic. i find people don't know what to look for or what a good ground actually is.
