Wire Verifications for Navi System
Hey all, back again with a wiring questions. I'm hooking up an Alpine NVE-N852a in my 05 Accord EX. The unit requires that I wire it to the
[ul][*]PARKING BRAKE SIGNAL LINE[*]VEHICLE SPEED SENSOR PULSE LINE[*]ILLUMINATION SIGNAL LINE[/ul] Can anyone verify where and what color each of these wires are? Appreciate all the help guys :D |
RE: Wire Verifications for Navi System
for speed sense it should be a blue/white wire at the ecm/pcm.
The ECM/PCM is on the front of the transmission tunnel. The connectors are on the passenger side. On the 4 cylinder models the VSS wire is in the white 31 pin connector E, pin 26. On the 6 cylinder models it is in the gray connector A, pin 11. illumination is red black at the radio harness and finally parking brake is the only wire that comes of the parking brake. Most likely u can just ground this wire though as it will allow u to put in addresses while u drive. |
ORIGINAL: porter351 for speed sense it should be a blue/white wire at the ecm/pcm. The ECM/PCM is on the front of the transmission tunnel. The connectors are on the passenger side. On the 4 cylinder models the VSS wire is in the white 31 pin connector E, pin 26. On the 6 cylinder models it is in the gray connector A, pin 11. illumination is red black at the radio harness and finally parking brake is the only wire that comes of the parking brake. Most likely u can just ground this wire though as it will allow u to put in addresses while u drive. I know I have a 4 cylinder but I have no clue about the 31 pin connector...but im sure I canmanage and find it. Is there anyway to bypass the parking brake deal? Or is bypassing it the same as grounding it? |
yeah grounding it is bypassing it
that wire should be easy to find u can test it with a digital multi meter
Cool. I will definatly try all this and hopefully get it to work. Thanks for you help porter
Is there any other Illuminator that I can use aside fromt he one from the radio headunit??
yeah u can go under the dash and fing pretty much any red black wire might be the parking lights. just test with a multi meter. ull almost definatly find one in the kick panel by the fuse box. just make sure u test the wire before taping into it.
