Film on rear window (inside),looks like cig smoke
New 2013 Accord Touring V6 with 35 km's and the inside back window has this film on it that looks like someone has smoked a whole carton of smokes and the smoke built up on the rear window. Probably just fumes from the plastic and fake leather collecting on the window?. Do you have film on your back window (inside?) Thanks HB
Originally Posted by Hot Brass
(Post 326426)
I too started to have this film in the top corners of the rear window. It began when I moved to a much hotter climate and seems worse in the summer. It can be removed only to return. It is, what it is.
Originally Posted by fvansan
(Post 326458)
my accord is a 2005 and the fogging began about 3 years ago when I moved to North Carolina. How old does the car have to be?
To be quite honest, the older the better. Why? Because as soon as the outgassing stops, the cracking of the dash and other plastic parts starts. The outgassing is the process which protects the plastic parts from the sun and heat, and as you found out, the warmer the climate, the faster the film on the glass will build up.
Thanks! A PITA to clean along the bottom of the window,maybe 2-3 inches up,close to the third brake light....not much room?! Thanks,HB
