bumper srcatches
My white Honda Accord 2016 have three srcatches on the bumper.
I use the touch up paint from the dealer - brush type. The two smaller srcatches are covered by the touch up paint. However, the largest srcatch (1 inch long) is still not covered. The "black" color of the bumper still appears. What should I do? |
Sounds as if the scratch is into the plastic, if so, you'll need primer, paint and clear coat. You may want to contact a reputable paint & body shop... most good shops can do an area touch-up with livable results... as it is only an inch long, the cost should be minimal
Originally Posted by Prospector
(Post 368783)
Idk if you guys know but wd40 helps a lot too.
