2013 Accords - Front brakes squeal or scrape
Honda has a technical service bulletin regarding this for the Accords.
Note: Technical service bulletins are not recalls, unless specifically noted as related to a recall; generally, they are to help Honda technicians with known issues. Issues noted in TSBs do not necessary apply to all vehicles. Normal warranty applies. Honda TSB 12-081 Front Brakes Squeal or Scrape SYMPTOM While turning, a squealing or scraping noise is heard from the front brakes. PROBABLE CAUSE The disc brake pad retaining clip (retainer) shifted and is touching the rotor. VEHICLES AFFECTED 2013 Accord – 2-Door L4 (Except LX) From VIN 1HGCT1...DA000001 thru 1HGCT1...DA002001 2013 Accord – 2-Door V6 (Except LX) From VIN 1HGCT2...DA000001 thru 1HGCT2...DA000937 2013 Accord – 4-Door L4 (Except LX) From VIN 1HGCR2...DA000001 thru 1HGCR2...DA050377 2013 Accord – 4-Door V6 (Except LX) From VIN 1HGCR3...DA000001 thru 1HGCR3...DA009828 CORRECTIVE ACTION Center the retainer in the brake pad holder, and apply a thin coat of Molykote M77 to the edges of the brake pads where they contact the retainer. |
