94-97 EGR Ports Cleaned
Here's a link;
http://www.freewebs.com/hondadude/95...5AccordEGR.htm |
You can search d8N-SE047VY on YouTube for a good video.
That is one of the best instructionals I've found online. And B12 is the best IMHO.
EricTheCarGuy has a great video on it too. We aren't supposed to have direct links. Removed the link, because that is the video I referenced above - PaHonda And don't forget there's a bleeding bolt on the end of the fuel rail you can loosen/remove so you don't have to worry about spritzing fuel all over your engine. Circled in red. Just take that bolt off and put a rag under it while you work on the other disassembly, when I did this it just start drooling fuel whenever it wanted to until it was empty. Just don't pop out the injectors until you open that up and relieve some pressure. http://img34.imageshack.us/img34/4154/bleeder.jpg |
the link has stopped working
Here some new links:
"http://www.freewebs.com/hondadude/95%20Accord%20EGR/95AccordEGR.htm" Copy and paste the above link without the quotation marks (" "). http://home.comcast.net/~em-engineering/T2T013.pdf |
link still doesn't work
2 Attachment(s)
