Request For 94-97 Steering Wheel Removal/|Answered
Hi guys!
This request is for a tutorial on removing a steering wheel properly and safely from a 94-97 Accord. Also include how to remove and replace the switches (turn signals and wipers) as well. This would be a much appreciated tutorial. Thank you peace out, daddy |
Disconnect battery,, make sure to have the radio code if anti-theft radio
Remove air bag assembly as follows: Remove mounting screw covers. Remove mounting screws using T30 Torx bit. 1 on each side Disconnect electrical connectors, then remove air bag assembly. When storing a removed air bag assembly, ensure pad is facing upward .\ Ensure steering wheel is in a straight ahead position, then remove steering shaft nut or bolt. i think that it is a 19 mm nut ,, wheel might just come off if you pull up on it.,, if not,,, use steering wheel puller.Do not tap on wheel or steering column shaft when removing wheel . . the switches are pretty easy just remove the screws and unplug the electrical connectors |
There You Go Member
1 Attachment(s)
:) Desert is our resident tech who also owns one of the better Honda Shops in the country...
WheelBrokerAng :D |
