DRL FIX .. by ECKHART
On behalf of HAF,,, i would like to tank ECKHART. for writing up this post...I am sure it will help someone ..
FROM ECKHART... Hi, I'm hoping you can post this great fix for a typical 92 (to 02) daytime running light fix (Might be for Canada cars only). My symptoms were: DRL light on all the time. Even when emergency brake was released. When hi beams would be turned on the passenger side hi beam did not work. Replaced all 4 bulbs and no change. Found an article that the problem may be the DRL Relay. I followed the instructions and fixed it. It is as simple as removing the module, taking the circuit board out and re-soldering the joints. Here is the article, with pictures: http://www.nyx.net/~smanley/hondadrlfix/index.html |
