HOW TO,,,,CLEAR SRS LITE
(should work for all honda)
On every single accord i have worked it has been located under the dash, left side ,, it is a yellow ( SRS connectors are all yellow ) 2 wire connector,either ( gray..gray ) or( green ,, green ) on occasion it is a pain to locate it ,, but it is there .. *tools- paperclip, flashlight , SCS connector ( if possible ) ,,most of you do not have the scs connector so just use paper clip Once you find it,, jump the wires together, use SCS connector or , Insert paperclip ... WHEN YOU DO THIS YOU HAVE TO BE FAST ON CONNECTING AND DISCONNECTING , whatever you use to jump the wires,,, if you have the SCS service connector it would make the job a lot easier.. Erasing the DTC memory/resetting SRS light 1) turn ignition switch off 2) jump the SRS ( MES) connector ( MES = Memory Erase Signal ,) using the scs connector or paper clip 3) turn ignition switch to on 4) The SRS indicator light will come on for about 6 seconds, and then go off. Remove the SCS service connector ( paperclip) from the MES connector within 4 seconds after the SRS indicator light went off 5) The SRS indicator will come on again. Reconnect the SCS service connector ( paperclip,) to the MES connector : within 4 seconds after the light comes on. 6) When the SRS indicator light goes off, remove the SCS service connector ( paperclip ) from the MES connector within 4 seconds. 7) The SRS indicator light will blink 2 times indicating that the memory has been errased/clear. 8) turn the ignition switch to off and wait for 10 seconds. it should be cleared.........If not repeat the procedure....... Hope this helps some of you... |
| All times are GMT -5. The time now is 08:29 AM. |
