Do-It-Yourself Section This section is for requests for DIY help, not for general technical advice.
How to remove rear seats in 02 Accord
Old 05-18-2010, 06:51 PM
decij's Avatar
Default How to remove rear seats in 02 Accord
My son lost a lego part through the opening for the seat belts in the bottom part of the back seat of my accord. If I try to pull up the back seat on the lower back of it on the right and left sides, I can tell those portions come up easily. Apparently, there is something in the middle holding the seat down. Would appreciate any advice I can get as to removing the back seat.
Thanks,
JD
Old 05-18-2010, 09:37 PM
The picture is for a 4-door, you didn't say...
Feel in the crack between the seat base & seat back. You're looking for the bolt #30. (probably use a 10mm socket?) It's not dead-center, it's towards the left (drivers) side of the car. See the little tab sticking up from the seat base in the picture.
Remove that one bolt; then the seat base can slide a bit forward & unhook the forward edge.
Old 05-18-2010, 10:29 PM
decij's Avatar
Default How to remove rear seats in 02 accord?
Jim,
Thanks a lot. Will give it a try. By the way, I grew up in Cleveland, lived in Columbus for a long time, and am currently in Cincinnati.
Best wishes,
JD
Old 05-19-2010, 07:10 AM
I was just down there. My wife ran 10k in the Flying Pig.
Old 05-18-2017, 02:17 PM
Default Picture?
I need to remove the seat base of my 2002 Honda Accord. How do I see the picture associated to this message?
Old 05-19-2017, 08:09 AM
That's been so long ago that Majestic Honda probably changed around their site.
Go to www(dot)hondaautomotiveparts(dot)com
Or www(dot)hondapartsnow(dot)com
(Or your favorite on-line parts store probably uses the same pictures from Honda's electronic parts catalog)
Click "parts".
Enter your car's information.
Pick the category that has seats & interior or something like that.
Old 05-19-2017, 06:26 PM
or see this - don't let the title throw you off.
Plus it would help to know if your car is a two or four door.
https://www.hondaaccordforum.com/for...removal-59143/
Vandal
11-16-2011 12:50 AM
Torino
11-23-2009 07:52 PM
justinit
09-24-2009 04:56 PM
djmuk
06-19-2009 04:48 PM
easterr
07-05-2007 11:50 AM
Quick Reply: How to remove rear seats in 02 Accord
